VeriStand System Mappings Not Updated After Interacting With Mapping Diagram Tool
Updated Nov 6, 2020
I am using VeriStand Mapping Diagram Tool to connect two channels as inputs of a Calculated Channel, but after performing this operation I am not able to see the related mapping in the VeriStand System Mappings.
This is an expected behaviour: since a Calculated Channel does not expose its inputs as channel, you won't be able to see a channel connected as input of a Calculated Channel as an item of the System Mappings.This behaviour does not depend on the Mapping Diagram Tool, you are going to have the same result if you specify the Calculated Channel inputs directly in VeriStand System Explorer.
