Multisim performs Worst Case Analysis using the following process:
- Simulation is first performed with nominal values.
- A Sensitivity Analysis, either AC or DC, is performed to determine the sensitivity of the specified components on the output voltage or current.
- Worst case parameters are determined by adding or subtracting the tolerance value from the nominal value.
- Simulation is performed with the component parameter values that will produce worst case values at the output.
Assumptions: Applied to an analog circuit, DC and small-signal. Models are linearized.
Running Worst Case Analysis
Consider the Wien-bridge oscillator circuit shown in Figure 1. The feedback to the non-inverting pin is designed to stabilize the amplitude of the oscillator, thus R1-R4 must be chosen carefully to ensure this circuit will oscillate. The following two conditions must be met:
Figure 1. Wien-bridge oscillator circuit.
In this example you will use Worst Case Analysis to determine if the circuit will continue to oscillate under the worst conditions.
Complete the following steps to configure and run a Worst Case Analysis:
- Open circuit file wien_bridge.ms11 located in the Downloads section.
- Open the Oscilloscope front panel and run the simulation. Observe the sinewave generated by the oscillator circuit.
- Stop the simulation.
- Select Simulate»Analyses»Worst Case. In the Model tolerance list tab you can select which tolerance parameters will be used. Note that a tolerance for R1 has already been added.
- Click Add tolerance. The Tolerance dialog window appears. Configure this window as shown in the following figure:
Figure 2. Adding tolerance parameters.
- Click Accept. R2 is added to the list of tolerances.
- Repeat steps 5 and 6 to add tolerances for R3 and R4. The dialog window will look like the following figure:
Figure 3. Model tolerance list.
- Select the Analysis Parameters tab.
- Set the analysis settings as shown in Figure 4. Refer to Table 1 for details on the different analysis parameters.
Figure 4. Worst Case Analysis parameters.
Table 1. Parameters used in Worst Case Analysis.
Parameter
Meaning
Analysis
| Defines the type of analysis required. This can be DC Operating Point or AC Analysis. If you select an AC Analysis, the Edit Analysis button will enabled. Click on this button to configure Frequency Parameters. |
Output variable
| Output variable to be monitored. |
Collating Function
Specifies the operation to be performed on the values of the output variable to reduce these to a single number that will be used in the sensitivity calculations (this option is enabled when you select an AC Analysis). There are five functions available:
- MAX: Finds the maximum value of each waveform.
- MIN: Finds the minimum value of each waveform.
- RISE_EDGE (value): Finds the first occurrence of the waveform crossing above the threshold (value).
- FALL_EDGE (value): Finds the first occurrence of the waveform crossing below the threshold (value).
- FREQUENCY: Finds the value at a specified frequency.
Direction
Describes what kind of output will be generated and limits the range over which the Collating Function operates. Multisim supports the option:
- HI/LOW: Specifies which direction the worst case run is to go relative to the nominal run.
Change Filter
| Filters the variables displayed to include internal nodes (such as nodes inside a BJT model or inside a SPICE subcircuit), open pins, as well as output variables from any sub-modules contained in the circuit. If you click on the Expression checkbox, the Change Filter button will change to Edit Expression; select this option if you need to create a custom expression. |
Note: In SPICE, the command that performs a Worst Case Analysis has the following form:
.WCASE <ANALYSIS> <OUTPUT_VARIABLE> <FUNCTION> [OPTION]
Note that these are the same parameters that were defined in Table 1, however, in Multisim you do not have to worry about the SPICE syntax.
- Click Simulate. Results are displayed in Figure 5.
The Worst Case Analysis section shows the DC Operating Point at V(OUT) for both nominal and worst case. The Run Log Descriptions section displays the resistance values required to achieve the greatest difference from the nominal value.
Figure 5. Worst Case Analysis results.
Inserting the output results in the two conditions for oscillation:
As you can see, only one condition is met, therefore, the circuit may fail if the components tolerances are not carefully chosen. Try entering the worst case values in the Wien-bridge circuit. Does it oscillate?
For AC circuits, the Worst Case Analysis generates separate plots for the nominal and worst case runs. A list of the components and their worst case values appears in tabular form. You can find an additional example file (speech_filter.ms11) in the Downloads section. In this case, resistors and capacitors of the Speech Filter circuit are varied to see the effects in the AC response.
