If this is the first time you are using Multisim, then you will quickly see that it is similarly a schematic capture and simulation environment, however, what are traditionally multistep or difficult processes have been simplified to make simulation easier. For this tutorial, you will require the
Multisim environment.
PSPICE to Multisim Tutorial: Placing Resistors and Capacitors
Opening the Software
In PSPICE, you will have traditionally opened the “Schematics” application via the following step (Programs >>PSPICE Student >> Schematics), prior to simulating the design.
To open Multisim, you must access Start >> All Programs >> National Instruments >> Circuit Design Suite 11.0 >> Multisim 11.0.
Placing the Op-Amp
In PSPICE, you need to open the “Get New Part” window and then search for “opamp” in the description box. After searching for the appropriate model, and attaching it to your device symbol, you can click “Place and Close.” It is then time to orientate the part appropriately. By double-clicking on the Op-Amp, you can set parameters for simulation.
To place a component in Multisim;
- Select Place >> Component.
- In the “Select a Component” dialog box, set the interface to the following settings circled in red (Figure 1). You have now selected the Analog group, and the ANALOG_VIRTUAL family.
- In the ‘Component Field’ select OPAMP_3T_VIRTUAL (circled in red).
- Click on OK, in the yellow box to place the part.
- Place the OPAMP in your schematic area with a left-click of the mouse.
- Right-click on the component and select “Flip Vertical”
- The schematic will now look as it does in Figure 2.
Figure 1. Select a Component Interface
Figure 2. Operational Amplifier
In PSPICE, you would now return to the “Use Get New Part” and search for a component named “R” and “C,” which describes a resistor and capacitor, respectively. Once you have placed two resistors and one capacitor on your schematic, you need to set the values on each component by double-clicking on each and individually changing the parameter value.
To place the resistors and capacitors in Multisim:
- In the “Select a Component” dialog box, set the dialog to the following settings circled in red. You have now selected the Basic group and the Resistor family (as in Figure 3)
- In the "Component Field" type the value of the resistor – in this case 2K - as in the blue field.
- Place the resistor in your schematic area with a left-click of the mouse.
- You still return to the Component Selection guide.
- In the “Select a Component” dialog box, set the dialog to the following settings circled in red. You have now selected the Basic group and the Resistor family.
- In the ‘Component Field’ type the value of the resistor – in this case 1K.
Figure 3. Placing a resistor
- In the “Select a Component” dialog box, please set the interface to the following settings circled in red. You have now selected the Basic group and the Capacitor family (figure 4).
- In the "Component Field" type the value of the capacitor – in this case 0.08u - as in the blue field.
Figure 4. Placing a Resistor
- Your design should look like the Figure 5 now.
Figure 5. Your Design at the End of Stage 1
PSPICE to Multisim Tutorial: Adding Power Components
Adding Voltage Sources and Ground
In PSPICE, you now return to the “Use Get New Part” and search AC voltage sources, which are denoted as VAC. You will need to search out a parameter called ACMAG, which is the AC Magnitude. Place the part. Next search for a ground symbol called GND_EARTH.
To place the sources in Multisim:
- In the “Select a Component” dialog box, follow these dialog setup directions: Select the Sources group and the SIGNAL_VOLTAGE_SOURCES family.
- In the "Component Field" select AC_VOLTAGE, and place in your schematic. It is pre-configured to 1V.
- In the “Select a Component” dialog box, follow these dialog setup directions: Select the Sources group and the POWER_SOURCES family.
- In the ‘Component Field’ select GROUND, and place in your schematic.
- Your design should look like Figure 6.
Figure 6. Your Design at the End of Stage 2
PSPICE to Multisim Tutorial: Wiring Components
Wiring Process
In PSPICE, you must now search for and select the “Draw Wire” button, or select an option for the Draw menu. You can only then connect the various nodes.
Multisim uses a modeless wiring environment, allowing you to easily draw net connections:
- Orient the mouse near a pin, for example the + pin on the V1 AC_Voltage source. As the mouse comes close to the pin it will change from a mouse cursor to a cross-hair. It is now ready to draw a net connection to resistor R2.
- Left-click the mouse, and a red line will appear after the pin. As you move the mouse, the red net (wire) will follow. Move it toward another component pin, and left-click to make the connection.
- Use this method to complete wiring your entire design, so that it looks like Figure 7.
Figure 7. Completed Schematic
PSPICE to Multisim Tutorial: Setting Up a Simulation
Setting Up an Analysis
In PSPICE, you will now set up an analysis. The analysis setup requires setting node names, enabling a certain type of analysis from a single “analysis interface,” and setting the start frequency (Start Freq), stop frequency (End Freq), points per decade (Pts/Decade), and sweep type (Decade).
In Multisim, the process has been somewhat simplified.
- Select Simulate >> Instruments >> Measurement Probe
- Place the probe with a left-click of the mouse at the output of your circuit. The node is now called “Probe 1”.
- To change its name double-click on the yellow field, and in the “RefDes” section, rename the probe from “Probe 1” to “Vout” (Figure 8).
Figure 8. Placing a Measurement Probe
- Select Simulate >> Analyses >> AC Analysis… You will have now opened the AC Analysis dialog box.
- Set the “Start frequency (FSTART)” to 10
- Set the “Stop frequency (FSTOP)” to 1 and the scale to MHz
- Set the “Number of points per decade” to 101
- Set the “Vertical Scale” to “Decibel”
PSPICE to Multisim Tutorial: Running a Simulation
Running an AC Analysis
In PSPICE, to view simulation data, you must open a plotting window and via the “add trace” button, or trace menu, plot various values and parameters onto the axis. You also need to do things such as create a decibel scale through an expression.
In Multisim, you need to follow these simple steps:
- In the AC Analysis dialog box, set the “Vertical Scale” to “Decibel”
- Select the “Output” tab
- In the “Variables in Circuit” section, select “V(Vout)” parameter
- Click on the Add button
- Click on the Simulate button. You will now see your simulation data (Figure 9)
Figure 9. Multisim Analysis Data in the Grapher
- To find the -3db point, you first need to select your cursors. You can do so by first clicking on the cursor item in your toolbar. The cursors will appear at the top of your Y-axis (in the red box of Figure 10)
Figure 10. Setting Cursors
- Right-click on the green cursor arrow on your Y-axis
- Select Set Y_Value =>
- In the Value field type -3
- Click on OK. The cursor has found your -3dB point (Figure 11).
Figure 11. -3dB point
