Error -2147221480 Illegal Parameter Name When Compiling DLL in LabVIEW
Updated Jan 31, 2022
Programming Language
  • C
My VI runs as expected, but when I try to build to a DLL, I am getting multiple C syntax error messages like the following:
Error-2147221480:
An error occurred compiling the DLL because a function or parameter name is illegal. Please verify that the function and/or parameter names are legal C identifiers and do not conflict with LabVIEW headers.
Additional Information: SharedLib.c - 9 errors
In most of the cases, this error is related to a conflict with the name of the variables or the components inside the VI with the 'C' programming language.
In order to solve this issue:
  • Please verify that you are not passing string data with the incorrect method. (See Create LabVIEW DLL to Pass Strings)
  • Review the syntax error that the error message is stating and verify if in some of your VIs there is a component called that way, if so, please re-name all the components and try building your DLL again.
  • Go to DLL >> Properties >> Advanced and deselect the "Include a type library for TestStand or Call Library Nodes" checkbox.
