NI ELVIS III Appears Under Devices and Interfaces in NI MAX
Updated Oct 27, 2020
  • NI ELVIS III
  • NI ELVIS III Software Bundle
  • Based on the manual, NI ELVIS III should appears under Remote System. Why it was appeared under Devices and Interfaces
  • Do I need to install any software to make the NI ELVIS III device appears under Remote Systems in NI MAX?
Yes. The NI ELVIS III should appears under Remote Systems in the configuration tree in NI MAX. To resolve the issue, you may need to install NI ELVIS III Software Bundle. You can use NI Package Manager to install it.
