Is It Possible to Use the Ethernet Port on My CompactRIO to Communicate with TCP/IP Protocol?
Updated Apr 20, 2023
  • cRIO-9039
  • LabVIEW Base
  • LabVIEW Real-Time Module
  • NI CompactRIO 18.5
Is it possible to communicate with a third part device using TCP/IP protocol with CompactRIO Ethernet port?
Yes, you can do it using the TCP/IP functions located on the Functions >> Communication >> TCP palette.
The process involves opening the connection, reading and writing the information, and closing the connection.
The image below shows a simple server client communication :
Server
Client
It is possible to find an example that implement the TCP/IP communication in:
Help >> Example Finder >> Data Communication >> Protocols >> TCP >> Simple TCP >> Simple TCP.lvproj
