Changing the Values of an Enum Constant
Updated Mar 26, 2019
In my application, I need to change the values of an Enum Constant from 0, 1, 2, ... to arbitrary numbers, e.g. 0, 7, 1000. Is this possible somehow?
The values of an Enum Constant are always sequential and starting from zero.
A Ring Constant however allows defining arbitrary values:
The Ring Constant is located in Functions Palette » Programming » Numeric. Un-check Sequential values as shown in the screenshot above to allow editing the defined values.
Note: The default representation of a Ring Constant is U16 (0..65535). To allow other values and/or decimals, you need to change the representation:
