It is not possible to create an executable application with
Vision Builder for Automated Inspection (VBAI). However, you can run your normal inspection files in VBAI with a
Run-Time license. There is not a separate installer for the VBAI Run-Time. Rather, you would
download and install the normal VBAI installer on your deployment computer and then use a Run-Time License to activate the components to run an inspection. With the Run-Time License you are unable to edit or create new inspections on that machine and can only open existing inspections in the VBAI Inspection Interface.
If you want to write a VBAI inspection, then run that same program on another computer, you need one Full development license and one Run-Time license. You would install VBAI on both computers and use different activation codes for each.
