Details on the Options with BeginMemoryOptimizedReadMultiSample ReallocationPolicy for DAQmx
Updated Mar 24, 2019
There are two overloaded functions by the same name, BeginMemoryOptimizedReadMultiSample, one of which has the extra ReallocationPolicy parameter. But if read the Remarks for each function, they seem to be the same. What is the difference between them?
Calling BeginMemoryOptimizedReadMultiSample(Int32, AsyncCallback, Object, array<Double>[]()[]) is the same as using BeginMemoryOptimizedReadMultiSample(Int32, AsyncCallback, Object, array<Double>[]()[], ReallocationPolicy) and setting the ReallocationPolicy=ToGrow.
