Cannot Find the Python Dll Using Python Analysis Procedures in DMSS
Updated Mar 22, 2019
  • Data Management Software Suite
  • Data Management Software Suite 2018
Programming Language
  • Python
I create an an analysis server procedure with python envirenment in DIAdem, but I get an error Cannot find the python DLL when I add the procedure into analysis procedures library in DMSS (Data Management Sotfware Suite ). How can I fix the problem?
You should set up environment well according to the manual Installing the Python Work Environment. One thing to note is that the python version must be 3.6. You can enter python in cmd to check the python version installed in your server.
