Error -251022 Occur Using Domain Name Connection in SystemLink
Updated Mar 25, 2019
  • SystemLink
  • SystemLink Server
  • SystemLink Client
The SystelinLink client can be connected to the server using both domain name and IP address. The issue is if I use the domain name, the Skyline.SendFile.vi will get an error -251022, the same error will also occur when transfering tag and message in AMQP. The error code and screenshot are shown below.
Error -251022 occurred at
niSkylineFileIngestion.lvlib:Open AMQP
Configuration.vi:2820001
However, if I use HTTP configuration to transfer tag and message or change the domain name into IP address, it works without any errors.
How to fix the issue?
It might be an issue verifying the RabbitMQ certificate for the server. This check is only done when specifying the master's hostname and isn't done when specifying the server's IP address. You can add your server's hostname to the SystemLink Server Configuration Utility RabbitMQ tab to fix the error.
