Closing of Execution Window in TestStand Sequence Editor
Updated Mar 21, 2019
  • TestStand
After the execution of sequence file, sequence or group of steps, one or more execution windows are opened. How can I close Execution Window in TestStand Sequence Editor?
There are two ways how to close execution windows in TestStand Sequence Editor:
  1. Right-click on header tab of execution window and choose Close.
  2. Use the keybord shortcut Ctrl+D. This will close all currently opened execution windows.
If you are using the batch or parallel process models, you also have the option to hide execution windows completely. Set the current process model to batch or parallel process model. Then choose Configure -> Model Options. Check the check-box Hide Execution Windows. When you run your sequence, it will execute normally, but the execution window and the report will not be shown.
