What Ports Do I Need to Open on My Firewall for Communicating with CompactRIO?
Updated Apr 28, 2026
  • CompactRIO Controller
If I need to install a CompactRIO in the corporate network, which ports do I need to open on the firewall in order to communicate with the device?
To communicate with a CompactRIO (depending on what you application needs to do), you must open the following ports:
  • MAX Hardware Identification - UDP 44515, UDP 44525, TCP 44516
  • Ethernet Target Device Discover - UDP 44525, UDP 5353
  • LabVIEW RT TCP front panel connections - TCP 3079
  • NI Service Locator - TCP 3580
  • Using LabVIEW Web Server - TCP 8080
  • NI VISA Server - TCP 3537
  • FTP server - TCP 20, TCP 21
  • Synchronization (NTP, SNTP) - TCP 123
  • Network Shared Variables and Network Stream - TCP 2343, UDP 6000-6010, TCP 59110 and above (one port for each application running on the server)
  • NI-RIO server for remote FPGA communication - uses dynamic port by default. The port can be checked in http://<cRIO IP address>:3580/dumpinfo, in the NI-RIO row under the mappings token. This will change with every server restart or reboot. To set a static port, you can modify the file /var/lib/nirio/ini/nirio.ini (by default this file does not exist, you can create it under the ini directory) and add the following token:
[General]
RpcServerPort=yourPortNumber
It's possible to collect this information from this guide: Configuring Software and Hardware Firewalls to Support NI Products.
The same ports are also relevant for Real-Time PXI systems.
