Simply, there are two ways to import excel data using LabVIEW whether you own Report Generation Toolkit or not. It is the more convenient way to use Report Generation Toolkit.
With Report Generation Toolkit
If you use LabVIEW Professional edition, you can read the Excel data directly from LabVIEW by using the included Report Generation Toolkit. Please refer to the following page for this example.
Reading Excel Data Programmatically Using the Report Generation Toolkit community post Note : To view the list of toolkits that are installed, Open the NI MAX software. Then, pull down the
My system » software. For further information, please refer to this link.
Which Versions of LabVIEW Run-Time Engine Do I Have Installed?
Without Report Generation Toolkit
If you do not have a toolkit, you can use the
Read Spreadsheet Read VI or the
Read From Measurement File express VI in the LabVIEW built-in functions.
In this case, it is necessary to save the Excel file as a
*.csv or
*.txt file. Please refer to the following document.
Reading Microsoft Excel Numeric Data Into LabVIEW
