If you are using an unsupported operating system (such as a Windows PC) for deployment (using a LabVIEW executable) then LabVIEW will generate Error -44247 as seen below:
You may use NI-Industrial Communications for DNP3 on non-supported platforms for prototyping and debugging, but deployment can only occur on supported hardware. The following is supported hardware for the NI-Industrial Communications for DNP3 driver:
- NI CompactRIO controllers with real-time OS
- NI PXI/PXI Express controllers with real-time OS
- NI PXI Express controllers with Windows OS
You may see
Error -44199, as seen below, indicating that the DNP3 Run-Time Engine has not been installed on your Windows PXI Express controller.
You may download the DNP3 run-time system by following the appropriate link in the related links section of this document. However, this run-time system will
only work for PXIe Windows controllers.
