Execute Case Structure Once
Updated Apr 27, 2019
I have a case structure in a while loop. When a boolean control is true, I want to run the case once.
Using boolean constants and logic this can be done. See below for implementation example
If you would like this to run the case again, You can reinitialize the boolean shift register to false.  See below for implementation example:
