Out of the box, NI DIAdem can read in file formats from the National Instruments platform. This includes
TDM, TDMS, LVM and
DAT files.
In cases where you want to read in data from a different file extension, you will need a DataPlugin.
The
HEAD_Data_Format DataPlugin DataPlugin supports reading/importing and writing / exporting of HEAD acoustics formatted data files. Reads and writes HEAD acoustics data file format "HDF", which defines the storage of "HEAD acoustics data sets"
Follow the steps mentioned below to Import .hdf files in NI DIAdem :
1. Download the
HEAD_Data_Format DataPlugin.2. Refer
Installing a C++ DataPlugin in DIAdem to install the DataPlugin.
3. Once installed, open NI DIAdem and locate the file on your disk using
My DataFinder.4. Right-click on the File->Select
Open With..
5. Select the right DataPlugin from the Dialog Box and click on
Load.
You should now see the file correctly loaded in Data Portal.
- When you use HEAD_Data_Format_Plugin to import your data those have to be multiplicated with the map faktor to show correct values. When this should be done automatically please use HEAD Data Format Scaling Plugin to import your data.
