Why is FFT not available for Calculated Channel in Flexlogger
Updated Jun 16, 2026
  • NI-9234
  • cDAQ-9174
  • FlexLogger
  • NI-DAQmx 18.6
I acquire vibration signals using NI 9234 with FlexLogger. I would like to perform Fast Fourier Transform(FFT) for calculated channels but I find no option to do so.
Formulas for calculated channels only contain standard math operators, functions, and constants. Refer to the Calculation Formula Options to check all formulas you are able to use.
For ordinary I/O channels, you can easily perform FFT, just use the FFT Graph in the Screen section.
