Voltage Spikes When Using Analog Input Pad in SCB-68A
Updated Mar 24, 2019
  • SCB-68A
  • PCIe-6321
  • NI-DAQmx 18.6
I am using analog input pad in the SCB-68A to do signal conditioning. When I do the acquisition with high-frequency signals I notice spikes in my acquisitions.
Why?
Each analog input pad has 8 pin, connected as the following image :
As you can see there is a 0Ω resistor in the F and G position . You must remove the resistor to use the positions.
if it not removed it is possible to parasitic phenomena, especially with high frequency signal.
To desolder the resistor use a low-wattage soldering iron (20W to 30W). Use only rosin-core electronic-grade solder to avoid damages the printed circuit device and components
