Execution of External Command, Script or Application Failed When Installing Software on cRIO
Updated Apr 9, 2019
  • CompactRIO Controller
Installing software on (a new) CompactRIO fails with the following message:
Execution of external command, script or application failed.
  • Verify that firewall has been turned off or at least NI Software is supported.
  • Reformat the device.
  • Power cycle the device.
  • Change the method you are using to connect to the cRIO (switch to Ethernet if connected through the USB B port) and format he cRIO with the new connection type.
  • Turn off any Antivirus software.
