What Is Accuracy of Output Voltage Measurement of RMX-4121?
Updated Mar 25, 2019
  • RMX-4121
What is the accuracy of voltage measurements of RMX-4121? In specifications, I can only see setting accuracy of output signal but no measurement accuracy.
RMX-4121  is not a measurement. the device, but a Programmable Power Supply. Does not measure voltage, it just sets some voltage on the output with some accuracy. To measure the actual output signal you have to use different, measurement device.
