Power Requirements for NI-9860 with CAN or LIN Bus
Updated Mar 7, 2019
  • NI-9860
  • Transceiver Cable
I want to use the NI-9860 C Series Vehicle Multiprotocol Interface Module and want to know the requirements I need to power the module, transceiver cables, and the bus for both CAN and LIN communication.
Here are the power requirements for the NI-9860 and the associated communication type:
Communication ProtocolRequires External Power to NI-9860Requires External Power to Bus
CAN Low Speed (LS)yesno
CAN High Speed (HS)yesno
LINyesyes
  • The TRC-8543 does CAN Low Speed (CAN LS/FT) and CAN High Speed (CAN HS/FD) communication.
  • The TRC-8542 does CAN High Speed (CAN HS/FD) communication.
  • The TRC-8546 does LIN communication.
