Verify NI R Series Multifunction RIO Device Drivers Q1 2019 Patch Installation
Updated Mar 8, 2019
  • NI R Series Multifunction RIO
  • NI R Series Multifunction RIO 19.0
I installed the NI R Series Multifunction RIO Device Drivers Q1 2019 Patch, but cannot tell whether or not the software was installed successfully.
I checked in NI MAX and it doesn't appear that my Software has been updated.
To check that the update has been installed successfully you can verify the version of NI R Series LabVIEW 2015-2018 Support (32-bit) in NI Package Manager.
1. Launch NI Package Manager
2. Under the "Installed" Tab, make sure to check the box "show full version numbers and hidden packages"
3. Look for the NI R Series LabVIEW 201X Support (32-bit), and check that it matched the version in the table below.
PackageVersion
NI R Series LabVIEW 2015 Support (32-bit)15.52.49152
NI R Series LabVIEW 2016 Support (32-bit)16.02.49152
NI R Series LabVIEW 2017 Support (32-bit)17.04.49152
NI R Series LabVIEW 2018 Support (32-bit)18.52.49152
To understand more about this patch, please read through the Patch Details.
