I would like to use my
NI-9870 or
NI-9871 VISA Module in a daisy-chain configuration using any CompactRIO Chassis and any of the EthernetRIO expansion chassis mentioned in the Reported In section.
I successfully followed the instructions in the whitepaper:
Connect an Ethernet RIO Expansion Chassis to a Secondary Ethernet Port on a Real-Time Controller. When starting my Project using only the EthernetRIO chassis and my host computer I can successfully open a VISA Ressource on either the NI-9870 or NI-9871.
When I try to access a VISA resource from my CompactRIO system using the daisy chain configuration from the whitepaper, I receive
"Error -1073807343 occurred at VISA Open
Possible reason(s):
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system."
