How Can I Access a Case-Structures Subdiagram Label Using VI-Scripting?
Updated Mar 20, 2019
Other
  • VI Scripting
I am trying to read/write the text of a subdiagram label of a specific case of a case-structure in LabVIEW. How can I achieve this?
You can use this code in a SubVI to read all subdiagram label text values.
A case-structure consists of multiple frame-objects. The subdiagram labels are part of the frame and can be found in the frames properties.
To use this code you need to enable VI-Scripting:
Tools -> Options -> VI-Server -> Show VI Scripting functions, properties and methods
To obtain a case-structure reference you may use the "Open VI Object Reference"-function from the scripting palette.
