LabVIEW NXG WebVI: Disabling the Mousewheel Scrolling on Graphs
Updated Aug 23, 2019
  • LabVIEW NXG
  • LabVIEW NXG Web Module
Is there a way to disable to zooming in/out (using the mouse scroll wheel) of my WebVI graph in LabVIEW NXG?
There are two approaches on how this feature could be disabled:
Item Properties:
On the LabVIEW NXG environment, right-click on the graph item on the Panel then choose Properties. On the properties pane, click on Item, then look for the Behavior sub-pane. Tick the Disabled radio button, and from here on, the mouswheel scrolling for your graph would be disabled.
Property Node:
To programmatically disable the zooming in and out on the graph of your VI, you should pass a True value to the Disabled Property of the graph as shown below on the snippet below:
