Error code -201167 I Can't Reserve a cDAQ Chassis Under NI-MAX
Updated Mar 5, 2019
  • cDAQ-9188
When I want to reserve my cDAQ chassis under NI-MAX, I get the error -201167. How can I solve it?
There are a number of reasons as to why you could see this issue, please follow the suggested options below:
First :
  • Check to see if your chassis is not being reserved/used by another system or software
  • Check to see if you have successfully connected the cDAQ chassis to your PC
If the options above do not solve the issue please try:
If you are still experiencing the issue please contact National Instruments Support
