Which Are the Value of Termination Resistors in CAN_H and CAN_L of PXI-8513?
Updated Mar 30, 2019
  • PXI-8513
  • NI-XNET
I would like to know the value of termination resistors of CAN_H and CAN_L in PXI-8513
The value depends on which transceiver is selected :
  • High-Speed CAN/Flexible Data‑rate
  • Low-Speed/Fault-Tolerant CAN
  • Single Wire CAN
The ISO standard requires single wire transceivers to have a 9.09 kΩ resistor, and no additional configuration is supported.
As you can see in the PXI-8513 Specifications the different transceiver depends on the revision of the board.
