My Text Ring Control Skips the Last Element When Pressing on the Upward Button
Updated Apr 3, 2019
My Text Ring Control has Data Items from 1 to 6 as shown below:
When I press on the upward button on the Ring Control, it skips the last element, the element with Item "6" in this case. It loops in this sequence, 1>> 2>> 3>> 4>> 5>>1 >> 2 and so on. How can I include the last element?
Check if you are doing any coercion by Right clicking on the control>> Data Entry. In this case the settings were as shown below:
As shown in the figure, Entry Number 0 is below the limit and it will be coerced. In this case this is the item "6". Change the minimum to 0 or check the "Use Default Limits" box and the Entry "6" will be shown in the sequence.
