IC-3173 (IP 20)
The following table outlines which cables and connectors are available for use with the IP 20 version of the IC-3173:
| Accessory | NI Part Number |
| 44-pin D-SUB male to pigtail cable, 3 m | 156083-03 |
| 44-pin D-SUB male to 44-position D-SUB female cable, 3 m | 156084-03 |
| 44-pin D-SUB male to 44-position D-SUB female cable, 0.5 m | 156084-0R5 |
| DisplayPort to VGA adapter cable | 782271-01 |
| DisplayPort to DisplayPort cable, 1.8 m | 782989-01 |
| I/O Accessory and 44-pin D-SUB male to 44-position D-SUB female cable, 3 m | 783327-01 |
| I/O Accessory and 44-pin D-SUB male to 44-position D-SUB female cable, 0.5 m | 783328-01 |
| Panel Mounting Kit | 784791-01 |
| 10-position modular plug to 9-pin D-SUB serial cable for RS-485 or RS-232, 1 m | 182845-01 |
| 10-position modular plug to 9-pin D-SUB serial cable for RS-485 or RS-232, 2 m | 182845-02 |
| 10-position modular plug to 9-pin D-SUB serial cable for RS-485 or RS-232, 3 m | 182845-03 |
IC-3173 (IP 67)
The cable and connector information for the IP 67 version of the IC-3173 can be found listed throughout the
IC-317x User Manual . The cables and connectors are organized by the type of connection. Tables for each type of connection can be found with a description of the cable or connector and its associated NI part number.
