Licensing OPC UA Toolkit Custom Device in NI VeriStand
Updated Oct 12, 2021
  • VeriStand
  • LabVIEW OPC UA Toolkit
I created a VeriStand custom device using LabVIEW OPC UA Toolkit.  What type of licensing do I need to use this custom device on systems that only have VeriStand?
A VeriStand custom device that uses LabVIEW OPC UA Toolkit will require the deployment license for LabVIEW OPC UA Toolkit.  You will also need to have the LabVIEW OPC UA Toolkit Runtime installed on the machine.
