Yes, you can use third-party OPC Servers with NI Lookout. Below are the steps to do so:
- New Process >> New Object >> Driver >> OPC Client
- In the Create OPC Client window, select your desired OPC Server from the drop-down menu in the Server Name field.
- Fill out the other sections of the Create OPC Client window as needed and click OK.
