Sub-VI Control Doesn't Display Value When Called
Updated Oct 9, 2026
In my code, I'm calling a sub-VI. I open the sub-VI's front panel to look at the controls and indicators update, and the values aren't changing. Why aren't my values being passed to my sub-VI?
This is being caused by your reentrancy settings. Open your VI Properties by clicking File >> VI Properties.... Switch to the Execution category and look at your Reentrancy settings as shown below. If your reentrancy is set to anything besides Non-reentrant execution, the code is being run in a clone of the VI in memory, separate from the open front panel. To see the values updating, set the Reentrancy to Non-reentrant execution to execute the code in the open copy of the sub-VI.
If your settings are set to allow Preallocated clone reentrant execution, you can double-click on the VI within the calling VI, and it will open up the allocated clone and show you the inputs and outputs changing.
