Programmatically Rename Aliases in LabVIEW
Updated Mar 8, 2019
  • System Configuration
How can I change the aliases of hardware without using NI-MAX?
You can rename aliases using LabVIEW with the NI System Configuration API located in the functions palette under Measurement I/O. The Rename Alias VI provides this functionality. A shipping example, Rename Aliases, can be found in the NI Example Finder
