Can I Use SignalExpress Code Generation with the LabVIEW Base Development System?
Updated Feb 21, 2019
  • SignalExpress
  • LabVIEW Base
I want to use the SignalExpress code generation feature in LabVIEW Base Development Environment. Is SignalExpress code generation available with the LabVIEW Base Development System?
No, SignalExpress code generation is unfortunately not supported in the LabVIEW Base Development System. There is no support for this operation because the LabVIEW Base Development System does not include many of the features required to support the Express VIs that are generated by SignalExpress Projects.
There are some cases in which you can still convert a SignalExpress Project into LabVIEW code, but it will either result in a blank VI or an Express VI that gives an error when run. In either case, the only solution is to upgrade your version of LabVIEW to the Full or Professional Development System and then reinstall SignalExpress.
