How Do I Delete Elements From an Array on the Front Panel in LabVIEW?
Updated Feb 21, 2019
  • LabVIEW Base
  • LabVIEW Professional
How can I delete individual elements and groups of elements from an array on my front panel in LabVIEW?
  • To delete individual elements from an array, right-click inside the element that you wish to remove and select
    Data Operations»Delete Element.
  • To delete a group of elements from an array, you must inform LabVIEW of the Start Selection and the End Selection. To do this, follow these steps:
1. Set the index of your array to the desired start of your selection.
a. Right-click on the array index
b. Select Advanced»Start Selection
2. Set the index of your array to the desired end of your selection.
b. Select Advanced»End Selection
3. Cut the text.
b. Select Data Operations»Cut Data
