Error -805 Configuring a Timed Loop Structure
Updated Mar 7, 2019
  • cRIO-9040
  • cRIO-9030
  • LabVIEW Real-Time Module
I have a Timed Structure that is used under RT Linux CompactRIO with 1MHz configuration. For testing purposes I would like to use the same code with the My Computer target under Windows with 1 MHz configuration. I have the issue that passing directly the string with the clock source does not work:
    In order to overcome this error:
    • Use directly the 1MHz source from the configuration dialog
    • Use the Create Timing Source VI that basically does the same thing of connecting directly the constant but assigns a particular name that you decide on the timing source.
