Toggle Key Binding Within XControl
Updated Feb 20, 2019
Is possible to use Toggle Key Binding for XControl items?
There is no direct way how to do this, but you can program workaround which acts like this function.
You have to create Event Case for the specific Key in Facade.vi of XControl. When XControl is focused you can use the Key which is specified for some functionality.
In the demo you can see that the necessary key combination for action is Ctrl + PageUp or Ctrl + PageDown.
In the Main VI you put focus on the XControl when Ctrl Key is pressed and when Ctrl Key is released the focus is also released.
