Vision Acquisition Express VI Is Missing After Installing Vision Acquisition Software 18.5
Updated Jun 4, 2021
  • Vision Acquisition Software
After installing Vision Acquisition Software 18.5, I can no longer see the Vision Acquisition Software (VAS) express VI in my LabVIEW palette.
This is a known issue in VAS 18.5 with LabVIEW 2015, 2016 or 2017 where the menus and supporting folders for the Vision Acquisition Express VI are missing. There are two solutions depending on the LabVIEW version you are using.
LabVIEW 2016 or newer
The issue was fixed on VAS 19.0, which is only supported on LabVIEW 2016, 2017, 2018 and 2019. If you are using any of these versions of LabVIEW the recommended solution is to go ahead and install VAS 19.0
LabVIEW 2015
To add the missing Vision Acquisition Express VI for LabVIEW 32bit follow the steps below:
  1. Download and unzip the attached VAS Express Support 18.5.zip folder and copy the following files in your LabVIEW directory, located under: C:\Program Files(x86)\National Instruments\LabVIEW 201x
  2. Copy the contents of the help folder located in \VAS Express Support 18.5\help to C:\Program Files (x86)\National Instruments\LabVIEW 201x\help
  3. Copy vision8.mnu located in \VAS Express Support 18.5\menus\Categories\VisionMotion to  replace or add it to C:\Program Files(x86)\National Instruments\LabVIEW 201x\menus\Categories\VisionMotion
  4. Copy the Vision Acquisition folder located in \VAS Express Support 18.5\vi.lib\express and add it to C:\Program Files(x86)\National Instruments\LabVIEW 2017\vi.lib\express
  5. Copy the Vision Acquisition Express Utility VIs.llb located in \VAS Express Support 18.5\vi.lib\vision\driver and add it to C:\Program Files(x86)\National Instruments\LabVIEW 2017\vi.lib\vision\driver
To add the missing Vision Acquisition Express VI for LabVIEW 64bit follow the steps below:
  1. Download and unzip the attached VAS Express Support 18.5.zip folder and copy the following files in your LabVIEW directory, located under: C:\Program Files\National Instruments\LabVIEW 201x
  2. Copy the contents of the help folder located in \VAS Express Support 18.5\help to C:\Program Files\National Instruments\LabVIEW 201x\help
  3. Copy vision8.mnu located in \VAS Express Support 18.5\menus\Categories\VisionMotion to  replace or add it to C:\Program Files\National Instruments\LabVIEW 201x\menus\Categories\VisionMotion
  4. Copy the Vision Acquisition folder located in \VAS Express Support 18.5\vi.lib\express and add it to C:\Program Files\National Instruments\LabVIEW 2017\vi.lib\express
  5. Copy the Vision Acquisition Express Utility VIs.llb located in \VAS Express Support 18.5\vi.lib\vision\driver and add it to C:\Program Files\National Instruments\LabVIEW 2017\vi.lib\vision\driver
