EtherCAT 18.0 Installation Error File Not Found CompactRIO9233.xml
Updated Feb 28, 2019
  • CompactRIO Controller
  • NI-Industrial Communications for EtherCAT 18.0
When trying to install Industrial Communications for EtherCAT V18.0 on a CompactRIO CRIO-9081 Chassis, the installation fails and it is required to re-format the CRIO hard-drive to get the system working again.
When the installation fails, I get the following message:
NI-CRIO9081-2F15D03A(192.168.2.20):
The specified file was not found:
Local File was not found.
Local File: C:\programfiles(x86)\national instruments\rt images\indcomecat\18.0\DD\CompactRIO9233.xml
Remote File: /ni-rt/system/IndComECAT/DD/Modules/CompactRIO9233.xml
This is an issue which has been fixed in the NI-Industrial Communications for EtherCAT 18.0 f1 Patch
