Can I Deploy the NI-Industrial Communications for IEC-61850 on Windows?
Updated Jun 20, 2025
  • CompactRIO Chassis
  • PXI Controller
  • LabVIEW Real-Time Module
  • NI-Industrial Communications for IEC 61850
Can I deploy the NI-Industrial Communications for IEC-61850 driver on Windows?
The NI-Industrial Commmunications for IEC 61850 software driver is a set of functions used to create IEC 61850 outstation or client applications. You can program theses functions on Windows computers for development and debugging and then deploy them on NI Real-Time targets such as CompactRIO, Single-BoardRIO, and PXI for field application. However it is not licensed for deployment on Windows-based computer.
Certain sets of VIs work on Windows PCs. Therefore, they can be used for simple testing, prototyping, and debugging on Windows PCs. For example, the following pair of example programs consists of such VIs and, therefore, can communicate with each other without NI Real-Time targets.
  • Server: Access BCR.vi (found in IEC61850 MMS Server.lvproj)
  • Client: Read BCR.vi (found in IEC61850 MMS Client.lvproj)
However, many of the VIs are supported only by NI Real-Time targets. Hence, to take full advantage of the driver, one should consider purchasing it on the basis that the actual program will be deployed to an NI Real-Time target. Refer to the Readme for hardware requirements for VIs.
