Support for Web services was introduced in LabVIEW 8.6 for Windows and LabVIEW Real-Time Targets. The Web services runtime engine in 8.6 and 2009 is loaded and run by LabVIEW's built-in Web Server.
In LabVIEW 2010 the Application Web Server is installed and runs by default on Windows PCs. This web server hosts all LabVIEW-built Web services and launches at system boot. Unlike earlier versions of the LabVIEW Web Server, the Application Web Server does not require LabVIEW to be running. The Application Web Server can be configured through the NI Web Configuration and Monitoring utility in a web browser. To use this utility you must install Microsoft Silverlight®. To launch the Web Configuration and Monitoring utility for your local machine, point a web browser to http://localhost:3580. From here you must select the Web Server Configuration Tool.
