USRP LabWindows™/CVI™ API
Updated Apr 15, 2019
  • USRP-2900
  • LabWindows/CVI
  • NI-USRP
I am looking to use my USRP device in LabWindows/CVI, but I have not been able to find an API. Is there ANSI C or C++ support with this driver?
If you are looking to work with USRP in text-based programming languages, you should use the Ettus UHD driver (USRP Hardware Driver), which supports C/C++ and can be used in the LabWindows/CVI environment. As per the latest NI-USRP (18.5) Readme, the software environments that support the NI-USRP driver are LabVIEW, LabVIEW NXG, and LabVIEW Comms, so there is no direct API available for LabWindows/CVI with the NI-USRP driver specifically.
