SH25M-10F 10-Pin Screw Terminal to 25-Pin D-Sub Cable Pin Mapping
Updated Jan 9, 2023
  • CompactDAQ Chassis
I need to know which pins on the 10-pin screw terminal map to the 25-pin D-Sub end of the SH25M-10F Cable for C Series modules.
The pins are mapped as follows:
Refer to your C Series Module's documentation for detailed information about each pin.
Refer to C Series with Screw Terminal Front Connection: I/O Cable & Accessory Guide to confirm the SH25M-10F cable is compatible with your C Series Module.
