このコンテンツは設定された言語で表示できません。
Archived:Is There a "Get Terminal Name with Device Prefix" Function in LabVIEW NXG?
Updated Dec 22, 2023
  • LabVIEW NXG
I have used the "Get Terminal Name with Device Prefix" VI in LabVIEW. Is it there a LabVIEW NXG version of this function?
The Get Terminal Name with Device Prefix function interacts with the DAQmx driver. This function is part of the DAQmx examples that get installed with the DAQmx support for LabVIEW NXG. In newer versions of DAQmx, it was renamed to Get Full Terminal Name.
In case you installed DAQmx after LabVIEW NXG, you can follow these steps to access the function:
  1. Open NXG
  2. Go to Help » Examples
  3. Navigate to: Hardware Input and Output » NI-DAQmx » Programmatic Configuration » DAQmx Synchronization
  4. Confirm a name for the demo project now being created
  5. You'll find Get Terminal Name with Device Prefix.gvi respecticely Get Full Terminal Name.gvi under subVIs in the pane normally on the left.
DAQmx is fully compatible with LabVIEW NXG since DAQmx 17.0 and LabVIEW NXG 1.0, see NI-DAQmx and LabVIEW NXG Compatibility.
Find information on how to find the Get Terminal Name with Device Prefix subVI in non-NXG LabVIEW in this article: Find Get Terminal Name with Device Prefix VI.
