Error -2503 When Opening a TDMS File in DIAdem
Updated Apr 10, 2019
  • DIAdem
I create a TDMS file with a LabVIEW program. When I try to drag and drop my TDMS file in the Data Portal in DIAdem, the following error appears. What can I do to avoid this error?
Cannot load the file "C:\Users\Public\TDMS_file.tdms" with the loader "TDMS":
Further information:
"TDS Exception in Initialize: Tds Error: TdsErrNotTdsFile(-2503):"
This error appears because the TDMS file is corrupted. Be sure you did not use this file while LabVIEW was writing data on it by closing the file on LabVIEW.
