Fatal Internal Error - 0x90FFFA4E: "AppEntryPoint.cpp"
Updated Dec 8, 2025
  • Mac OS X
LabVIEW crashes with the following error: Fatal Internal Error 0x90FFFA4E : "AppEntryPoint.cpp".
Follow the troubleshooting steps relevant for the operating system you are using:
Windows OS
MAC OS
Try uninstalling LabVIEW using the Terminal window.
Linux OS
In a Linux environment, this error may occur due to updates in software dependencies. NI driver software versions 18.0 and higher cannot be installed through your Linux distribution's package manager if there is a pre-18.0 NI driver on the system. Pre-18.0 NI drivers must be uninstalled first. After uninstalling you need to download and install the newer versions of the Linux drivers
Real-Time Target (Linux Real-Time OS)
This issue can happen when the MAX database is corrupted. The real-time target will not show up correctly under Remote Systems in MAX and you need to follow these steps to fix the issue:
1. Reboot your device.
2. Reset he MAX database by following the steps in this article: How to Fix or Reset the NI MAX Database File.
If the uninstalling process does not solve this problem, as a temporary workaround, try installing and running LabVIEW in a virtual machine. As another workaround, try creating a temporary new user and reinstalling LabVIEW.
In case for Fatal Internal Error - 0x90FFFA4E: "AppEntryPoint.cpp" at line 105 occurred in LabVIEW 2025 Q3, a bug case has been raised when the LabVIEW crash when Default Data Directory is map to restricted network drive. Refer to Bug 3595176 to NI Technical Support for more information. Possible workaround is deleting the INI file or otherwise don't use invalid directories.
