XNET Setup Guide in Scan Interface Mode
Updated Oct 30, 2023
  • NI-XNET
  • NI CompactRIO
I am trying to setup a NI-XNET module in a cRIO chassis. However, I cannot connect to the module. I do not own the FPGA module and therefore need to operate in scan interface mode.
  • In NI MAX the NI-XNET module does not show up and there is no option to manually add it, The module has been recognised in a LabVIEW project. However I cannot use the device in a VI.
  • Do I require LabVIEW FPGA module for the NI-XNET module?
You do not require the FPGA module in order to use NI-XNET devices. However, you will be limited by the lower performance of scan interface mode
In order to use a NI-XNET device in a CompactRIO you will require both the CompactRIO driver and the XNET driver to be installed onto the CompactRIO.
It is important to note that the NI-XNET drivers require a CompactRIO driver that is at least as recent. For example, NI-XNET 16.0 would require the CompactRIO 16.0 driver (or newer). NI-XNET 16.0 would not work with CompactRIO 15.0.
Once the necessary drivers are installed you can use the following steps to add the NI-XNET device to your LabVIEW project:
1 - Connect to cRIO from LabVIEW project
2 - Result: Bright green dot. Please note that the NI-XNET device is still not shown.
3 - Right-clicking on the cRIO and New » NI-XNET Session now lets you select the NI-XNET interface.
