Can I Transfer Hard Disks From HDD-8265 to Another One?
Updated May 3, 2019
  • HDD-8265
  • RAID Array
  • PXI RAID Controller Module
Can I transfer hard disks from one HDD-Raid 8265 to another, same RAID type?
As long as you are using the same computer, the driver will recognize the new hard disks automatically as the same storage volume that had been previously built on the old HDD-8265.
Also, the order of the drives actually does not matter, the HDD-8265 will recognize the volume in any order as long as all the drives are present.
NOTE: The recommendation is maintaining the same order and configure same RAID type.
