This KnowledgeBase describes how to silently register and install NI software through a NI Package Manager feed. In addition to this document, the following introductory topics from the NI Package Manager Manual may be helpful:
If you want to create a customised installer to install a specific list of NI software consider using
NI Package Builder instead.
Add Feed from a Local or Network Directory
- Use an PC with the desired software installed to Create a Custom Feed in NI Package Manager.
- Either copy the Feed Folder to the target system, or ensure the files are in a network location that target systems can access.
- Make sure NIPM is installed on the target. If not either download and install from the Package Manager Download Page, or follow How Can I Silently Install NI Package Manager?
- Open Command Prompt, or create a batch file with the following commands:
cd C:\Program Files\National Instruments\NI Package Manager
nipkg.exe feed-add "<file path of feed>"
nipkg.exe feed-update
nipkg.exe install <Package name> -y --accept-eulas
Make sure to change "<file path of feed>" to the file destination of the feed folder. This destination can be a local or network directory.
You can also give your feed a custom name. Make sure to create a simple feed name with no symbols or spaces. In the below example "NXG3feed" is used.
Example:
nipkg.exe feed-add --name=NXG3feed "C:\feeds\NXG3"
nipkg.exe install ni-labview-nxg-3.0.0 -y --accept-eulas
pause
Add Feed from URI
nipkg.exe feed-add <URI>
Example:
SCCM Usage: Create a Batch File Application in SCCM
You can distribute the suggested batch file above through SCCM by creating a Batch File Application or Package. Further information is provided in the System Center Configuration Manager Documentation:
